Go Back   Foromecanicos: Foro de Mecanica Automotriz > FORO DE MECANICA AUTOMOTRIZ > MECANICA AUTOMOTRIZ
Closed Thread
Thread Tools Display Modes
Old January 26th, 2010, 15:04
chacon chacon is offline
chacon Neutral
Default valvula IAC para un tbi 5.7, como es la instalacion?
es para un tbi 5.7, compre la valvula nueva la instale pero dura muy poco en las condiciones qe el motor requiere 600 rpm,, luego la valvula regresa a su condicion original de compra y esto ocaciona qe no baje de 1500 rpm,,
quisiera saber si hay algun paso en especial para la instalacion qe yo este ignorando??
Old January 26th, 2010, 15:39
pacoton pacoton is offline
pacoton Neutral
Default Re: valvula IAC
que modelo es tu camioneta?
que sistema trae de inyeccion?
a lo que yo se las revoluciones se regulan de acuerdo a el sensor de temperatura
yo cambie mi sensor y ahora en frio se acelera y cuando va tomando temperatura
se va desaselerando hasta quedar en la aceleracion que yo le tengo
mi sistema de inyeccion es TBI
Old January 26th, 2010, 15:44
pacoton Neutral
te dejo la teoria de funcionamiento de la valvula IAC
Idle Air Control (IAC) Valve
The IAC valve controls engine idle speed to prevent stalling during engine load changes. The IAC valve is
mounted on throttle body and controls the amount of air by-passed around the throttle plate. The IAC valve
controls engine idle speed by moving its pintle in and out in steps referred to as "counts" (0 counts, fully seated;
255 counts, fully retracted). Counts can be measured by plugging a scan tester into the Data Link Connector
(DLC).
If engine RPM is too low, pintle is retracted and more air is by-passed around the throttle plate to increase
engine RPM. If engine RPM is too high, pintle is extended and less air is by-passed around the throttle plate to
decrease engine RPM. Normal counts on an idling engine should be 4-60. When engine is idling, PCM
determines proper positioning of IAC valve based on battery voltage, coolant temperature, engine load and
engine RPM.
If IAC valve is disconnected or reconnected with engine running, IAC loses its reference point and must be
reset. On some models, IAC is reset by turning ignition on and off. Other models require driving vehicle at
normal operating temperature over 35 MPH with circuit properly connected. Problems in IAC circuit should set
a related code.
The IAC valve affects only the idle system. If valve is stuck fully open, excessive airflow into the manifold
creates a high idle speed. Valve stuck closed allows insufficient airflow, resulting in low idle speed. For
calibration purposes, several different IAC valves are used. Ensure replacement valve is proper design.
Old January 26th, 2010, 15:56
chacon Neutral
mi sistema de inyeccion tambien es tbi,, modelo 92,, lo qe le pasa a mi camioneta es qe no sostiene la marcha minima
Old January 26th, 2010, 16:02
pacoton Neutral
y cuando arrancas la camioneta se acelera?
el mio es tbi 4.3 yo te puedo ayudar con aportes solo pregunta
casi me se de todo de mi camioneta
saludos
  #6
Old January 26th, 2010, 16:04
pacoton Neutral
como te comento el sensor de temperatura regula las revoluciones (se acelera cuando esta frio el refrigerante) y el pulso de inyeccion
Closed Thread
valvula iac
Thread Tools
Display Modes
Posting Rules
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
valvula iac sablemercury MECANICA AUTOMOTRIZ 1 January 18th, 2010 14:55
valvula egr me marca el codigo po1400 sablemercury MECANICA AUTOMOTRIZ 5 December 23rd, 2009 15:43
valvula egr sebastian MECANICA AUTOMOTRIZ 1 October 13th, 2009 10:38
valvula pcv calitro MECANICA AUTOMOTRIZ 3 September 25th, 2009 19:50
Valvula EGR Blabo MECANICA AUTOMOTRIZ 0 March 19th, 2009 14:26
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
