Ayuda con Sincronisación de los arboles de levas(2) del Aveo 2009 1.6 L
va asi.................................................................................................
chevrolet aveo 2004/2007
    61,1 KB · Visitas: 17.848
CORREA DE SINCRONIZACION CHEVROLET AVEO 2009
    87,3 KB · Visitas: 13.073
    33,7 KB · Visitas: 2.161
Mas info de apoyo para banda de tiempo aveo 1.6L 4 cil LXV años 2008 a 2011
TIMING BELT, REPLACE
1.Disconnect and isolate the battery ground cable.
2.Disconnect the IAT (Intake Air Temperature) sensor electrical connector.
3.Disconnect the air intake tube from the throttle body.
4.Disconnect the breather tube from the valve cover.
5.Remove the air cleaner housing bolts, then the housing.
6.Loosen the righthand front wheel lug nuts.
7.Raise and safely support the vehicle with jackstands.
8.Remove the righthand front tire and wheel.
9.Remove the righthand front wheelwell splash shield.
10.Remove the accessory drive belts.
11.Remove the crankshaft pulley bolt, then the pulley.
12.Remove the timing belt upper front and lower front cover fasteners, then the covers.
13.Remove the power steering pump mounting bolts, but leave the hoses intact.
14.Install the crankshaft pulley bolt.
15.Rotate the crankshaft clockwise until the sprocket timing mark aligns with the timing belt lower rear cover notch, Fig. 1.
16.Loosen the coolant pump mounting bolts just slightly.
17.Rotate the coolant pump counterclockwise to release timing belt tension using GM timing belt adjuster tool No. J-42492-A, or equivalent.
18.Remove the timing belt behind the power steering pump.
19.Ensure the crankshaft sprocket timing marks are still properly aligned, Fig. 1.
20.Align the camshaft sprocket timing marks, Fig. 2.
21.Note any running direction marks, then install the new timing belt behind the power steering pump.
22.Rotate the coolant pump clockwise until the automatic tensioner adjust arm pointer aligns with the notch in the tensioner bracket using GM timing belt adjuster GM tool No. J-42492-A, or equivalent, Fig. 3.
23.Tighten the coolant pump mounting bolts.
24.Rotate the crankshaft clockwise two full turns.
25.Loosen the coolant pump mounting bolts.
26.Rotate the coolant pump until the adjust arm pointer aligns with the pointer on the tensioner bracket, Fig. 4.
27.Torque the coolant pump mounting bolts to 89 inch lbs.
28.Remove the crankshaft pulley bolt.
29.Install the power steering pump mounting bolts. Torque to 18 ft. lbs.
30.Install the timing belt lower front and upper front covers. Torque the bolts to 89 inch lbs.
31.Install the crankshaft pulley. Torque the bolt to 70 ft. lbs., then, using GM angular torque gauge tool No. J-45059, or equivalent, rotate the bolt another 30°, then an additional 15°.
32.Install the accessory drive belts.
33.Install the splash shield.
34.Install the tire and wheel, then lower the vehicle.
35.On 2008-09 models,torque the lug nuts to 88 ft. lbs.
36.On 2010 models,torque the lug nuts to 92 ft. lbs.
37.On 2011 models,torque the lug nuts to 103 ft. lbs.
38.On all models, install the air filter housing. Torque the bolts to 71 inch lbs.
39.Connect the air intake tube to the throttle body.
40.Connect the breather tube to the valve cover.
41.Connect the IAT sensor electrical connector.
42.Connect the battery ground cable.
43.Start the engine and ensure it operates properly.
    86,7 KB · Visitas: 1.247
    116,6 KB · Visitas: 3.078
    96,7 KB · Visitas: 1.351
    99,4 KB · Visitas: 614
CHEVROLET - AVEO 1.6L
CHEVROLET -CRUZE - 1.8L
CHEVROLET - SONIC - 1.8L
2009/2014
Codg Motor : LUW, LWE, LXV.
Banda de Tiempo - Correa de Sincronizacion - Timing Belt
Imagen Adjunta.
    87,3 KB · Visitas: 489
    33,7 KB · Visitas: 443
