Cambio sensor map Dodge
Cambiando el sensor map de un Dodge ram 1500 truck v8 5.7L vin 2- 2007
Removal and Replacement Sensor-MAP
The Manifold Absolute Pressure (MAP) sensor is mounted to the front of the intake manifold air plenum box.
1. Disconnect electrical connector at sensor by sliding release lock out. Press down on lock tab for removal.
2. Rotate sensor (3) 1/4 turn counterclockwise for removal.
3. Check condition of sensor O-ring.
Installation is the reverse of removal.
    100,6 KB · Visitas: 671
    110,2 KB · Visitas: 590
