Hola amigos, les comparto manual para poner a tiempo un chevrolet silverado 1994
6.5L DIESEL RPO L49, VIN P /RPO L56, VIN S / RPO L65, VIN F
tambien cubre estos temas
Rocke r Arm Cove r Replacement
Rocke r Arm Shaft, Rocke r Arms , an d Pushrod Replacement
Hydraulic Lifter Replacement
Hydraulic Lifter Repair
Valve Stem Sea l an d Valve Spring Replacement
Cylinder Head Replacement
Cleaning and Inspection
Cylinder Head Repair
Oil Pum p Drive Replacement
Torsional Damper an d Front Crankshaft Sea l Replacement
Front Cove r Replacement
Timing Chain an d Sprocke t Replacement
Camshaft Replacement
Cleaning, Inspection, and Repair
Dipstick Tube Replacement
Oil Pa n Replacement
Oil Pum p Replacement
Oil Pump Repair
Rea r Crankshaft Oil Sea l Replacement
Connecting Ro d an d Piston Replacement
Cleaning, inspection, and Repair
Main Bearing Replacement
Oil Filter Bypas s Valve Replacement
Engin e Mountings
Inspecting Engin e Mountings
Front Engine Mounting Replacement
Rea r Mounting Replacement
Engin e Replacement
Flywhee l Replacement
Manual an d Automatic Transmissions
Flywhee l Ring Gea r Replacement
Dual Mas s Flywheel Replacement (Manual Transmissio n Only)
Dual Mas s Flywheel Repair
Oil Pump Repair
Engin e Mountings
Engin e Replacement
