ESPECIFICACIONES DE TORQUE Y APRIETE PARA MOTORES HONDA 1.6L
MOTORES D16A, D16Z, D16Y
Manual Transmission
Counter shaft lock nuts..............................65ft lbs
End cover bolts.........................................9ft lbs
Selector arm holder bolts...........................9ft lbs
Tranny case to Flywheel housing...............20ft lbs
Tranny to engine bolts
4 speed.................................................33ft lbs
5 speed.................................................50ft lbs
Clutch pressure plate bolts......................19ft lbs
CLUTCH PRESSURE PLATE TORQUE PATTERN
_______1
_____6___3
_____4___5
_______2
Release fork bolts...................................22ft lbs
Drive axle/hub nuts..............................134ft lbs
Drive Plate bolts for A/T.........................54ft lbs
Flywheel Bolts M/T.................................76ft lbs
Flywheel Bolt ARP..................................87ft lbs
FLYWHEEL TORQUE PATTERN
_____1
_____6___8
___4_______3
_____7___5
_______2
Master Cylinder Mounting nuts................11ft lbs
Cylinder Head Spec's
Valve Sizes D16A6 Intake......29mm Exhaust....25mm
D16Z6 and Y8 Intake...30mm Exhaust....26mm
Other Torque Spec's
Wheel Lug Nuts....................................80ft lbs
Fuel Filter
Banjo Bolt..........................................16ft lbs
Service Bolt.........................................9ft lbs
Clamp Bolt...........................................9ft lbs
Brake line to caliper banjo bolts (front/Rear)...25ft lbs
Brake Booster mounting nuts.............................9ft lbs
Valve Clearance
Stock D16A6,D16Z6 and D16Y8 Cams
Intake.....007‐.009" (.17‐.22mm)
Exhaust...009‐.011" (.22‐.27mm)
Head Chamber Volume
D16A6......................38cc
D16Z6 and D16Y7.....34.6cc
D16Y8......................32.8cc
Throttle Body Sizes
D16A6..... 55mm
D16Z6......56mm
D16Y7......56mm
D16Y8..... 56mm
