pueta a tiempo de peugeot 206 motor 1.4
hola buen dia, quiero pedirles su ayuda para poner a tiempo un peugeot motor 1.4 me llego sin banda, es de 8 valvulas agradeseria su pronta respuesta.
huicho50 por favor mandame la distribucion de peugeot 206 1.4 ha kanizio con enlace directo tengo idea pero quiero asegurarme
TU ENGINE
[3] Camshaft setting rod (-).0132-RZ .
[4] Seem equipment for measuring the tightness of S.0192 type belt .
2 - REMOVAL
TU ENGINE
Remove : The engine suspension tie bars .
TU1JP ENGINE
Without removing the securing bolt(s) on the cylinder head, pull the bar (8) towards the exhaust manifold .
TU ENGINE
Remove the ancillary drive belt .
Move aside :
the injection-ignition control unit
the control unit bracket
Remove :
the crankshaft pulley
the timing covers
TU5JP ENGINE AL4 AUTOMATIC GEARBOX
Move the camshaft pulley close to the setting point by rotating in the normal direction of rotation .
ALL MODELS
Peg the flywheel using the rod [2] .
Peg the camshaft gear using the rod [3] .
TU ENGINE
Slacken the nut (4) retaining the roller tensioner (5) to slacken the belt (6) .
Remove the timing belt (6) .
