Torques Jetta GL 2.0L L4AEG 2001/2003
  • Iniciador del tema Iniciador del tema Tobe82
  • Etiquetas Etiquetas
    jetta
Especificaciones de Torques Jetta GL 2.0L L4AEG
años 2001/2003
Axle Shaft To Transaxle Flange Bolts 33
Axle Nut 195
Ball Joint To Suspension Arm Bolts 26
Camshaft Bearing Cap To Cylinder Head Nuts 15
Camshaft Sprocket To Camshaft Bolt 74
Clutch Pressure Plate (Driveplate) to Crankshaft 44 (1) (6)
Clutch Slave Cylinder 18 (5)
Connecting Rod Nuts 22 (1)
Crankshaft Pulley 30
Crankshaft Timing Belt Sprocket To Crankshaft Bolt 66 (1)
Cylinder Head Cover To Cylinder Head Bolts 84 Inch lbs
Cylinder Head Bolts (2)
Engine To Transaxle Bolts, M10 33
Engine To Transaxle Bolts, M12 59
Exhaust Pipe To Exhaust Manifold Bolts 30
Front Main Oil Seal Housing To Block Bolts 15
Front Engine Mount Bracket To Body 18
Front Engine Mount To Body 30 (1)
Front Engine Mount To Engine Bracket 44 (1)
Flywheel To Crankshaft Bolts 44 (1) (5)
Flywheel To Pressure Plate (Driveplate) Bolts 15 (6)
Intermediate Shaft Oil Seal Flange To Block Bolts 18
Intermediate Shaft Sprocket To Intermediate Shaft Bolt 48
Hub Nut 195
Lower Timing Belt Cover Bolts 84 Inch lbs
Main Bearing Cap Bolts 48 (1)
Oil Cooler To Oil Filter Bracket Nut 18
Oil Pan Drain Plug To Oil Pan 22
Oil Pan To Block Bolts 15
Oil Pressure Switch To Oil Filter Bracket 18
Oil Pump Cover To Oil Pump Housing Bolts 84 Inch lbs
Oil Pump Pickup To Pump Bolts 84 Inch lbs
Oil Pump To Block Bolts 15
Oil Spray Nozzle To Block Bolt 84 Inch lbs (5)
Pendulum Support To Engine 15 (1)
Pendulum Support To Transaxle 30 (1)
Power Steering Pump To Mounting Bracket Bolts 18
Pressure Plate to Flywheel 15 (5)
Radiator Mounting Bolts 84 Inch lbs
Rear Engine Mount To Body 18
Rear Engine Mount To Transaxle 44 (1)
Rear Main Oil Seal Housing To Block Bolts 15
Rear Timing Belt Cover To Block Bolts 22
Rear Timing Belt Cover To Block Threaded Bolt 22 (3)
Thermostat Flange Bolts 84 Inch lbs
Timing Belt Tensioner Nut 33
Upper Intake Manifold Bolts 15
Upper Timing Belt Cover Bolts 48 Inch lbs
Vibration Damper (Pulley) To Crankshaft Timing Belt Sprocket Bolt 74
Water Pump Housing To Block Bolts 15
Water Pump Pulley To Water Pump Bolts 15
Water Pump To Water Pump Housing Bolts 84 Inch lbs
Leyenda
1 --Plus an additional 1/4 (90°) turn.
2 --Refer to "Cylinder Head, Replace."
3 --Coat threads with D6 locking compound, or equivalent.
5 --Models w/02A transaxle.
6 --Models w/020 transaxle.
