Uplander 2005 sensor temperatura
Reemplazando el Sensor de temperatura del refrigerante (ECT) en un Chevy Truck Uplander FWD V6-3.5L VIN 8 año 2005
Procedures
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Coolant Temperature Sensor/Switch (For Computer) Service and Repair Procedures
PROCEDURES
ENGINE COOLANT TEMPERATURE (ECT) SENSOR REPLACEMENT
REMOVAL PROCEDURE
1. Engine coolant must be drained below the level of the engine coolant temperature (ECT) sensor. Refer to Draining and Filling Cooling System in Cooling System.
2. Remove the air intake duct.
imagen1
3. Disconnect the ECT sensor harness connector.
4. Remove the ECT sensor.
INSTALLATION PROCEDURE
Imagen 2
1. Apply thread sealant GM P/N 12345382 (Canadian P/N 10953489) or equivalent, to sensor threads.
IMPORTANT: Tap out sensor mounting hole in engine head to remove any thread sealant residue. Clean any sealant residue from old sensor and apply RTV sealant to threads if old sensor is going to be reused.
2. Install the ECT sensor.
NOTE: Refer to Component Fastener Tightening Notice in Service Precautions.
Tighten the engine coolant temperature sensor to 23 N.m (17 lb ft).
3. Connect the ECT sensor harness connector. Push in the connector until a click is heard, then pull back to confirm a positive engagement.
4. Fill engine coolant to proper level. Refer to Draining and Filling Cooling System in Cooling System.
5. Install the air intake duct.
    443,2 KB · Visitas: 680
    443,2 KB · Visitas: 365
